メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1200回答 すべてを表示
The Phone will not activate!
Hey All
ok i have an iPhone X and i restored the the phone to 12.1
since then i can not activate the phone.
Find my iPhone has been switch off before i don’t the restore its off on the system and its unlock to any network.
i have Dfu restored also with recovery on countable times
when i connect to wifi to active i get the error
“Your Phone could not be activated because the activation several is temporary down”
connect throw iTunes i get the error
“THE iPhone could not be activated because the activation information could not be obtained from the device.
i have tried other sim cards, it shows they get signal in top corner.
the phone was working with the sim card i used before.
Anyone know a way around it?
it just won’t activate
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
So, you are saying it works with other SIM cards but won’t work with a particular card? That tells me that the particular card that’s not working has failed. Get a new SIM card and it should be fine.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
no bro, it doesn’t activate with no sim card.
the phone will not activate.
さんによる
"i have tried other sim cards, it shows they get signal in top corner'." What is that about then?
さんによる
I have the same problem. I get a signal in the top right corner of the screen. I called my carrier and activated a new Sim card and I'm still getting the same error message
さんによる
Try to dial *#06# and see if the device returns its IMEI.
さんによる
コメントを追加
I’m having the exact same problem, please help :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Blanco さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 12
今までの合計 550
