メインコンテンツにスキップ
The Galaxy Tab S2 9.7 is a tablet released in 2016 by Samsung. This device comes in both 32GB and 64 GB variants. The Wi-Fi only model number is SM-T813. The factory unlocked 4G model number is SM-T819.
16回答 すべてを表示
mini-usb stick only recognising when forced in
Hi,
My tablet used to work normally with my usb stick (SanDisk Dual Drive, one end normal usb, one end min-usb) and I would routinely copy data from a laptop onto my tablet and vice versa. I’ve recently found that I really have to push the mini-usb end in quite far and hold it in there tight for the usb stick to show up on the tablet’s MyFiles app (I used to use a more sophisticated file browser but the built in one works fine). Obviously forcing it in is probably not a good long term idea so I was wondering if you guys had any thoughts? I’ve tried a wooden toothpick in the charging port to clean lint out but there wasn’t much in there and it’s still the same as before.
the usb stick works on other phones and the tablet charges fine through the charging port.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Sounds like your port is damaged in your tablet. There are different pins for different actions. So the power pins are working the data pins clearly are damaged here.
Review this IFIXIT guide: Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement jump to Step16 see the ports location. Unless you can fid the connector its self and have the needed tools to properly install a new one you’ll likey need to replace the lower logic board.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
before u replace the port.
get surgical spirit, and a tooth brush and clean it out.
gently make sure the phone is off and it dries after trying.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
therealtommyleek さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 5
今までの合計 158
