LG 65LB730 Screen problems, pulsating
Hi, my TV have randomly started pulsating some lines on the objects.
I’ve tried to reset the tv to factory settings and also upgraded/downgraded the fw and problem still issue.
Clip on the issue.
Clip on the issue.
Jakob Vesterberg
this could be an issue with the main board. Try different video input sources (HDMI, Composite, Coax etc.) and see if it remains. If so, I would consider replacing the main board.
このアンサーは役に立ちましたか?
You are experiencing a TV with an LED problem. Very common. I have repaired these under warranty. Your TV panel is the culprit. You may try to replace the LEDs. This is extremely difficult and can result in a complete waste of time. Recycle and shop for new. Thanks for asking, Matt of Martins TV Repair.
このアンサーは役に立ちましたか?
Then I know, thanks for the help :)
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 312
