How do I make the second monitor active if primary is down
Normally I would use Command F1 to make the external monitor active but there is no F1 key on the touch bar. Also the screen is broken so i can’t get into system preferences on the primary display. Need to turn off autoboot before putting new display on.
この質問は役に立ちましたか?
8 件のコメント
Won't removing the battery prevent the Mac from turning on whilst repairing it?
[deleted] さんによる
see step #1 Step 1 Disable Auto Boot on this guide. Just trying to follow directions
MacBook Pro 13インチ Touch Bar Late 2016のディスプレイアセンブリーの交換
mayer さんによる
I got the bottom off without activating the power on. Not easy!
mayer さんによる
@mayer I'm at a loss of understanding that removing the lower case could trigger the fastboot?
[deleted] さんによる
Obviously somebody did it or it wouldn't be in the guide. Lots of things get put in guides because someone had to first do it wrong.
mayer さんによる
3件以上のコメントを表示
