メインコンテンツにスキップ
長く待ちわびた人気モデルMac miniの最新モデルです。プロセッサはオプションで3.6 GHz quad-core Intel Core i3、3.0 GHz 6-core Intel Core i5もしくは3.2GHz 6-core Intel Core i7プロセッサから選べます。
20回答 すべてを表示
Solder an external power button to the latest mini?
Hi y’all,
Just got the latest Mac mini and I need to add an external power button to it with long wires so I can turn it on and off from a distance. In the previous models I was always able to trace back the wires to the pins and splice the cables but with this ultra flat cable now, anyone knows where I need to add my wires?
Thanks a bunch!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
3件の回答
ベストアンサー
If you are trying to setup a media server (or other server) you can setup wake on LAN which is what I would do.
このアンサーは役に立ちましたか?
スコア 3
12 件のコメント:
Thank you @danj , I think I figured it out and I’ll post my result on this forum cause, hey, might be useful for others. This year’s Mac mini’s layout makes it difficult to figure out which pins are the button ones because of the 8-pin flat cable. But I think I found them. I’ll try to turn it on and let you know hehe
さんによる
Do keep in mind if you alter the logic board or cable connection you will void your warranty!
さんによる
@danj did they get rid of the IR control?
さんによる
@mayer yes, they ditched the IR control. There is no more black piece of plastic under the sleep light which is where the IR sensor used to be.
さんによる
Sadly, I don't see any sensor window in the IFIXT teardown. Bluetooth or WiFi would be the only way you might be able to turn it on remotely wirelessly. I have mine (2011) setup to wake on LAN.
さんによる
7件以上のコメントを表示
コメントを追加
So what was the solution? You wanted to post it…
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I’d love to know how to bypass the switch I broke mine. I juts need to get it turned on !
さんによる
I also want to know this solution.
さんによる
コメントを追加
I created a Mac Mini M1/M2 Holder Vesa Mount with Switchbot and Servo Power Button Pusher you can print to use for this. https://www.printables.com/model/540401-...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jess B さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 37
今までの合計 2,111
