メインコンテンツにスキップ
KitchenAid Dishwasher runs intermittently but doesn’t clean
Fills with water-wash cycle stops/starts for hours but not cleaning. Cancel-Drain works fine. I’ve replaced the sump and motor and the control board but still getting a 4-3 error, which is not showing up in any searches.
A lot comments mentioned the door actuator not making good contact with the door latch switch in this thread that describes the problem .
Whirlpool Dishwasher stops after filling with water
Model #KDTE104ESS4
Another clue-burnt wires leading to control board (disconnected during control board installation)
Update (11/08/2018)
Thanks for responding. Yes filter is clean.
I don’t think the sprayer arms are moving any water. The tub fills and sometimes sounds like it’s working but top rack not wet.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
8 件のコメント
Did you check the float in the bottom right corner? If it’s stuck it won’t let the tub fill up properly.
さんによる
Yes float is functional.
さんによる
When I replaced the control board I noticed the outside of the panel wires that go the control board look burnt. Should/can I replace those?
さんによる
is the error definitely 4-3?
さんによる
Yes it’s 4-3.
さんによる
3件以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
Tying threads together for this issue, I have a potential solution here: Whirlpool Dishwasher stops after filling with water
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Have you checked the filter inside the unit? Page 16 and 17.
Also can you post a photo of your drain tube? The drain tube needs sufficient fall to prevent dirty water from backfilling the unit.
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
Yes it’s 4-3.
さんによる
I finally found an answer. The problem is the Circulation pump. Apparently this is different from the drain pump. If you replace the circulation pump you should be good to go.
Also I hear this part is expensive. Good luck brother.
さんによる
I'm having this same issue. Circ pump quit. Replaced with new assembly. Started it up and now it just keeps cutting on and off. I bet this is what caused the original motor to fail. Any suggestions?
さんによる
I am having the same issue. Self test shows a code of 4-3 indicating a problem with the wash pump circuit but both the pump and the control board have been replaced. Still has the same problem. The pump starts for only about 2 seconds and then shuts off. It seems to repeat that several times but the wash pump never run for more than 2 seconds.
さんによる
See the post I linked below. Mine also would work off and on and it was a loose connection.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Curtis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 75
今までの合計 4,446
