メインコンテンツにスキップ
An Android 4.4.2 smartphone released November 1, 2014.
Why cant I touch the screen on the phone
I think my mother board is gone out how do i fix it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
@khunt2002 Is the touch screen unresponsive?
さんによる
yes.. I cant make or recieve calls. I need service now....
さんによる
コメントを追加
1 件の回答
if your touch screen is unresponsive, there are a few things that could be going wrong.
1) most commonly, your digitizer is failing. The digitizer is the touch processing panel under your glass. you can try to get a new one and see if this fixes your issue.
2) this is less common, but will cost less to fix, which would be a software bug. run a factory reset through your recovery mode on you device to see if it fixes your touch.,
3) board level failure. the least common to cause a straight lack of touch, but the board may be having issues. without excessive training in Microsoldering, as well as access to the schematics for your device, you will be unable to repair this, and will have to replace the motherboard with one from another device instead.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What do I do?? I am expecting important calls.... No other phone to use. I have not contact inf.,.,.
さんによる
the quickest thing would be to buy another phone and switch the SIM. It may also be the most economical answer, especially if you buy a used one from Back Market, Swappa, even Walmart
さんによる
コメントを追加
回答を追加する
Kyra Hunt さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 5
過去 30 日: 145
今までの合計 370
