Phone is charging turns on its 1% then turns off and repeats
so my iphone 6s is charging its keeps turning on and is on 1% then shows passcode then turns off and turns on again its keeps staying at 1% please help me asap
It is likely that the battery has reach the end of its life cycle and will need replacing. That is the cheapest repair to try first. If that doesn’t solve the issue, then the next likely cause is either software corruption or Tristar chip on the logic board needs replacing. This is all assuming that the phone hasn’t had severe external or liquid damage. Hope this helps.
このアンサーは役に立ちましたか?
ok so i got a bit of water on my phone and it said it woult charge but now it is but once it turns on it'll say 1% but not charging then turn off, then turn back on and the same thing happens. what do I do.
Check: Settings-Battery-Battery health. If it’s below 90% (my 6s was at 88%) you may be able to get a free battery replacement from Apple. I did mine a few months ago and it’s like having a new phone.
Check this site: https://www.apple.com/support/iphone6s-u...
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 12
過去 30 日: 43
今までの合計 617
1件のコメント
Do you have a computer running macOS handy?
[deleted] さんによる
