メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Home button not functioning after a battery replacement
Following the iFixit battery replacement guide, I did a battery replacement a few months ago. After the battery replacement, my home button stopped working. It doesn’t register any presses and neither does Touch ID work.
My friend was doing a screen replacement on his 6S and it came with a home button. He intended on keeping his original home button, so I had asked if I could have his spare home button. However, when I installed the home button, it still did not work.
Now here’s where I think I went wrong. In the iFixit battery replacement guide, you are asked to separate the display assembly from the rest of the phone. While this step is not necessary, it would make life much easier when working on the rest of the phone.
There are 3 cables connecting the display assembly to the phone: the front camera cable, the digitizer cable, and the display cable.
I’m not sure which of these cables register home button presses, but I think I may have damaged that cable. Anyone have any other opinions as to what could be causing my home button to stop working after a battery replacement?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I would suggest going back and opening up the phone checking all the connections and check all of the pins were put back right and that they are not bent.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Melophile さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 57
