メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
774回答 すべてを表示
Magsafe 2 Connector Burnt
I got my MacBook repaired with this exact same issue in February of this year, the charging port has noticeable burn marks around the 2nd and 4th pins. Now once again it is having the exact same issues, has anyone else had a similar issue to this? What did you do to fix it? I have an apple generic charger, and the board for the magsafe was already replaced once.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Your answer is “generic” charger, the quality of which is probably far from what an original charger is. Just trash it and look for an original one, even a 2nd hand would do, but do not endanger an expensive logic board for a little saving on the charger. If it’s just the charging port that’s gone bad consider yourself lucky, at times everything gets burnt along the power/charging circuit. On top of that, uncertified chargers may be dangerous for you and your households as they may start fires.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
I worded that badly, it is an apple original charger, bought a new one when I got the MagSafe replaced in February.
さんによる
@bedoretj Well, never had a single problem with any of the hundreds of Apple chargers I had tried in many years. May I ask where did you buy it from ?
さんによる
the apple store in short hills, NJ
さんによる
That sounds like a reliable enough source to buy an Apple charger. Can't find any reasonable explanation to your issue then, besides severe voltage/current spikes on mains, is that a possibility ?
さんによる
If you are talking in terms of power surges, I have it grounded on the power strip that has surge protection.
さんによる
コメントを追加
This is not really a good answer, since the same happens with expensive original chargers. Right now, it has heppened about the 6th time with the original, 140 dollars in Costa Rica one
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
TJ Bedore さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 15
今までの合計 1,242
