メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Touch Screen not Working After Replacement
Hi ,
I’ve recently went to replace my 5s’ cracked screen to a new on only to discover that the touch on the new screen was completely unresponsive. Thinking I had a dud screen, I sent it back and got a refund.
I tested my original screen with my phone again and the touch worked fine.
Ordering a new screen again, I went to install it today and again the touch is completely unresponsive! The new screen is an original apple screen so I doubt it is faulty the second time, however I doubt my phone is faulty due to it working fine with the cracked screen.
Honestly any help on this would be appreciated, because im stumped.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The only thing I can think of is that you may have caused pry damage or long screw damage.
Did you put the screws back in the exact same location if not then that could cause long screw damage and prevent touch.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Make sure all your ribbon cables are properly seated. Ive had similar problems with iphones not working and the problem simply was a bad connection.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kmes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 13
今までの合計 68
