MacBook Air 13” 2017 Debug power button location?
My MacBook Air 13” 2017 has a broken power button. Anyone know where is the location of debug pads for power button? Greatly appreciate.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Often when I hear this the issue is a bad keyboard assembly or the ribbon cable and its connection on the logic board has an issue.
To test things heres the location of the power pads:
If that fails you’ll need to do some deeper testing.
このアンサーは役に立ちましたか?
Thank you for your great help.
Thanks for this help, it was a bad ribbon cable connection !
Happy it was a simple fix! Don't forget to accept the answer!
Great thanks, it perfectly worked to solve a bad keyboard
過去 24時間: 1
過去 7 日: 5
過去 30 日: 38
今までの合計 3,280
