メインコンテンツにスキップ
2.2 GHz (Turbo Boost up to 3.4 GHz) もしくは2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
463回答 すべてを表示
MacBook Pro - How to use external monitor right from boot/login screen
My macbook's display is not working, and it just shows some lines for most part of it. But I can see(barely) it is booting and waiting at login. I want to connect it to external display and take a backup. The problem is that the external display becomes secondary display and I do not see the login prompt on it to work.
Is there a way to make the external display the primary display or to mirror display using some keyboard shortcuts, as I cannot see whats on the screen at all?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
6件の回答
ベストアンサー
If you have access to a USB or Bluetooth keyboard & mouse. Restart your system and then close the lid so the lid sensor acknowledges the lid is closed your external display should automatically become the primary display.
If this fails you may have something deeper here than just a messed up LCD.
このアンサーは役に立ちましたか?
スコア 13
4 件のコメント:
Brilliant! Worked for me.
さんによる
You need the magsafe in and power on too. It doesn't work from battery.
さんによる
Worked for me
さんによる
worked for me too :)
さんによる
コメントを追加
Here’s a guide on how to do so. Pretty cool guide in my opinion!
http://osxdaily.com/2010/12/21/broken-ma...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
@ajcooke01 - Be careful! This guide was for the older A1211/A1212 MacBook Pro. The newer MacBook Pro retina series are a bit different. I wouldn't disconnect the display lid as you would loose Bluetooth & WiFi
さんによる
@danj I didn't say to disconnect the lid, it was just in the very unlikely case the OP would actually do something like that.
さんによる
コメントを追加
@thierrywilders I had this issue with the 2019 13” macbook pro 4TB port touch bar model. Like them, my external monitor would only come up in extended desktop/recovery mode even with the lid closed. The only solution that worked for me was to disconnect the LVDS display connector which forced the system to use the external display. Obviously you need an external keyboard/mouse for this to be practical. Mine were USB, I don’t know if bluetooth would have given the same result.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I made a slabtop of my 2018 MacBook Pro 15” but nothing showed up on my external screen and the internal was, well, in a happier place. Booting into recovery mode and disabling FileVault did the trick. After restart I came to the usual login screen
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hey Arvid, can you give me any tips on this process as I also have a MacBook Pro 15” 2018.
さんによる
Can’t remember exactly but I think I choose the third option in the recovery assistant and after a few steps there was an option of disabling FileVault.
さんによる
コメントを追加
I'm trying to connect Mac book pro 2019 from usb c to HDMI cable to Samsung TV before login. But it's not detecting in TV even after connecting charger and closing lid. Any idea why?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Try a different port, adapter and/or cable as one is not working properly.
さんによる
コメントを追加
So i have a macbook with usb-c/touchbar with a broken display and other boot problems.
The screen doesn't do anything and the touchbar sometimes shows something, the capslock light is working but no external screen, even with the lid closed/charger connected/external keyboard amd mouse. Any idea where to start?
Ps. I got internet recovery to work on the external screen but it was in extended desktop mode so i could really see anything....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Harish さん、ありがとうございました!
統計データ:
過去 24時間: 64
過去 7 日: 469
過去 30 日: 1,948
今までの合計 85,690
