メインコンテンツにスキップ
日本では1994年11月22日、北米では1995年5月11日、欧州では1995年7月8日にセガから発売された32bitの第5世代ゲームコンソールです。
Whats wrong with my Saturn when the screen flickers and scrolls?
The Sega Saturn powers on fine, but the screen flickers in black and white and scrolls up. Please help diagnose my Saturn!
-Sam
Update
Forgot to add, the din plug-in in the back of the saturn is a little messed up and where the pins fit in is bent up. When i jiggled the av cord where it goes into the saturn the screen goes black and when i let go the image comes back on with flickering and scrolling. Is it safe to assume that the bent av input is my problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
Well, yeah, that would do it! My mention of a faulty or damaged console was referring more to the innards of said console. Worst I own is a SNES with a partially broken AC-in jack (plastic barrel cracked, half of it is missing...works, but fits loosely). If the pins are all bent up or damaged in any way, then that would DEFINITELY be a prime candidate. I think we nailed it!
さんによる
Do you know of any affordable online sites that offer repair for such video game injuries?
さんによる
コメントを追加
1 件の回答
ベストアンサー
I will assume, by the description, that you're hooking this to a CRT (old tube TV). :p
The last time I had a console do what you describe, it turned out to be the AV input connection on the TV itself. While possible it is the cable, the symptoms usually ended up being different that you describe. Swapping cables, if you have a spare available, would be a great way to actually rule this out.
When you adjust the cable's position (aka "jiggling"), does it make a difference? Does it matter where along the cable you do this?
Check to see if the jack(s) is (are) loose in any way on the TV. If so, then the soldering that holds it may have cracked or broken in the TV. It might be fixable, but it's insanely dangerous and probably not worthwhile. (Met an electronics veteran who was lucky to be alive after accidentally brushing against the leads of a CRT capacitor early in his career. NOT RECOMMENDED!)
Your best bet, if the above mentioned diagnostic "jiggling" doesn't narrow down the cause, is to connect the Saturn to another TV, one that you know works. If you cannot reproduce the problem, then at least you know it's not the console or the cable. (Though honestly, I've never seen this problem be caused by a faulty or damaged console.)
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
+ Congratulation on achieving tee shirt level, if they're ever given out.
さんによる
+excellent answer. Hope they are sending you a T-Shirt soon ;-)
さんによる
コメントを追加
回答を追加する
Sam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 3,462
