メインコンテンツにスキップ
エスプレッソメーカーの修理情報です。
1487回答 すべてを表示
Mr. Coffee Cafe Barista - All LEDs blinking
Hi,
I have an Oster Prima Latte, it is essentially a Mr. Coffee Cafe Barista knock-off. The problem is that everything works “fine” excepts that no matter what selection a make (1 cup or 2 cups) the pump never stops, until security function detects the pump is on for too long and it self-set at error stage (all LEDs start blinking).
I’ve disassemble it completely, changed the O-rings on all the connections, cleaned all electronic conectors and circuit board, but nothing has solved this.
Hope you can help me with this.
P.S.: I have basic electronic knowledge and count with all the necessary tools: DMM, soldering iron, desoldering wick, etc,.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
So checking all the electronics, I came with the problem, it was the water flow sensor from the water reservoir, it has three (03) terminals with soldered cables covered with thermal shrinks, two of them were broken, but the thermal shrink doesn’t allowed me to see it. Removed the thermal shrink, re-stripped the cables, slide new thermal shrinks, soldered and it was done.
Didn’t kept photographic log of the process, maybe later i’ll do a disassembly guide and point to the details of the repair.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
Hi, I have the exact same machine(Oster prima latte)), and all my lights are blinking too, by reading the mr.coffee manual, i came to know that the machine is not detecting any water, even if the reservoir is full, so i believe you have the solution to my problem. I wish you do a fixit guide soon.
さんによる
Hi, give me some days and I'll build a disassembly and repair guide. Hope later I could help you with this. Happy holidays
さんによる
thanks for commenting buddy, I had nearly lost hope, and no service-person would touch this thing. Nice to see that something can be done, I haven't done much before but can get things done if shown how, currently I just have the protech kit with me.
Thanks and happy holidays.
さんによる
Hey man just wondering when will you post the guide, really appreciate it bro!
さんによる
If it’s the same espresso machine I have, Check the knob on the side and make sure it’s set horizontally- between the foam and the drip.
さんによる
コメントを追加
*Just as of curiosity, when you had this problem, does the cappuccino or latte program worked?
>Nothing worked buddy.
*I wasn't able to get in touch with Mr. Lau at the time, he solved his problem and deduced it as loose soldering of a water-sensor-part
Unfortunately for me as nature of my job has me away for many months, I have lost the reassembly photos and project still awaits me, as all parts have been kept seperate.
(RIC to Mr. Lau, if you're still active)
IF SOMEONE HAS EVEN AN AMATEURS GUIDE TO REASSEMBLY OF THIS UNIT, PLEASE POST.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi lau,
Just wondering buddy, when will you make that guide. I really want to get this fixed.
Thanks again,
-Yash
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hi Yash,
Contact me by email. I've been too busy lately, really, went out of home at 8:00am and came back at 2:00am. I've been moving my business from location and doing other stuff. That's why I haven't posted the guide. If you can skype or another video call, I could help you from my office.
さんによる
Oh brother I have tried searching for your email but couldn't, otherwise would have done it long ago. I just have your Twitter id and I absolutely don't know how to reach you in private message. Still haven't figured out your email yet :(. Mine is yashthegr897@gmail.com. please reach out
さんによる
Replace the flowmeter and everything will be OK. The magnets inside my flowmeter were broken. Google 'de longhi flowmeter' and you'll find the piece. https://www.amazon.co.uk/Flowmeter-Durch...
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jesus Lau さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 42
過去 30 日: 169
今までの合計 10,193
