psu cable completely stuck
The cable connecting the psu to the motherboard seems to be completely stuck, any tips on how to get it out without ripping off the socket?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hey, Fredrick. That cable is a little tight, however, it should pull out with just a little force. Take a pair of small needle nose pliers and grab onto the connector itself. Don’t pull in the wires or you’ll pull them out of the connector. Pull straight up and be sure your pliers are only gripping the connector and not the “socket” part. I hope this helps. Good luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 11
過去 30 日: 49
今までの合計 2,781
