メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2004年に発売された、自動霜取りシステムと結露防止ヒーターのスイッチを搭載したトップフリーザー冷蔵庫、Frigidaire GLRT183TD*の修理および関連情報。このページでは、GLRT183TD*の型番に該当するモデルの情報を扱っています。
Why my fridge won't run
I bought a used frigidaire refrigerator, model # GLRT183TDWH, it worked and was cold when I bought it. The gentleman said to lay it down in the bed of my truck for transporting. When I plugged it in it ran for about 30-45 seconds then stopped. The lights are working but it's not running.
I don't have the money for another fridge. Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The gentleman does not know what he is talking about.
Normally it is ok to transport a refrigeration unit in any orientation. The problem arises when it arrives at its final destination. The refrigeration unit is designed to operate only in the upright position. This has to do with the way refrigerant and lubrication oils settle inside the unit when it is turned off. The system is designed to leak down after it is turned off, so that when the it starts again, the compressor can start easily due to the low pressure on the compressor side of the system. If the unit is started soon after righting it, or while it is on its side, refrigerant may build to high pressure levels immediately upon startup. This is a good way to burn out your compressor. In short, there is no issue with transporting it that way, but it is always recommended to let it sit upright for at least a day before attempting to start it.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Chamber leak ho gaya
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dana さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 365
