メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Spectre x360 13-4101dx - 13.3" - Core i7 5500U - 8 GB RAM - 256 GB SSD
HP Spectre X360 13-4101dx Motherboard DA0Y0DMBAF0 - What is this part?
I’ve got a hp Spectre X360 13-4101dx laptop with charging issue. I found that small thing on the motherboard (1st picture), and its original place probably(2nd picture).
Anybody can help me that what the name of it and its function? Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
ベストアンサー
This is very far after the fact, but judging by the fact that Google pointed me here, other people are also looking for this information.
I believe this uses the same board? or is a rebrand of the Elitebook x360 1030 G3.Or at least this circuit is the same. But my board uses the same number.
Regardless, I had a nearly identical issue. The other capacitor right there went for me. A bit more catastrophically. Luckily, it was a client machine and not mine. And under warranty at the time. But I was digging through old pictures and got sucked down a rabbit hole. I was initially alerted by the hole in the sticker.
After digging up schematics and a board view, these are on the circuit for charge in. And are part of the charging circuit for the device. They are 22μF 25 V in an 0805 package.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It’s a capacitor. Since they usually unmarked, and the one you have is broken in two, you cannot find out its original value. So you need first to find out the package by measuring the size (width and length, maybe height) and compare to a list of standard capacitor sizes. The size will constrain the voltage x capacity product (ie. for a given size, if you get a higher voltage one, it will have a lower capacity). Then you need to measure the voltage on the pins (most likely a standard voltage like 3.3, 5, 12, 24). Finally find the capacitor with the size you measured, the voltage rating directly above the one you measured (or one higher), and the highest capacity.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
A little late, but that part is a surface-mount capacitor.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I ended up buying a refurbished mother board off of ebay. I believe it came from China. I plugged in my original ss hardrive from the broken MB. It started right up without any issues.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
voneout さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 32
今までの合計 1,597
