Multiple drive connections
I want a HDD, a SSD and a ODD on the iMac EMC 2428, is that possible? Where is the spare connector?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You can add a drive into the 27" model, OWC does this service. The 21.5" has no room inside. Here's how to add eSATA ports: http://www.xlr8yourmac.com/systems/imac_...
このアンサーは役に立ちましたか?
OWC has now added upgrade options for the 21.5": http://eshop.macsales.com/shop/turnkey/i...
Here's a guide for installing it: http://blog.chargedpc.com/2011/05/2011-i...
This in fact' 'is'' possible.
There are 3 SATA Data Connections on the motherboard. See image here.
There are also 3 Distinct Power connections on the motherboard shown in the image.
In order to retrofit a SSD into the new 2011 21.5" iMacs, You'll need the following parts:
539-1295 (SSD DATA)
539-1296 (SSD POWER)
And the brackets, which part numbers have not been identified for yet.
See image here for an idea of the fit.
このアンサーは役に立ちましたか?
Is possible, here's the complete guide:
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 2
過去 30 日: 6
今までの合計 2,788
