メインコンテンツにスキップ
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
382回答 すべてを表示
How to use my iMac 27" 2010 model as an external monitor with PC?
Plan to use my old 2010 iMac 27” as an external monitor and connect it with my windows’s desktop PC. However, have a hard time finding the video cable in the market. My PC has HDMI/DVI/DISPLAY ports on video card, and there is only mini display/thunderbolt port on iMac 27”, there are lots of mini Display port to HDMI/DVI/DISPLAY in the market, but not on the opposite way, anyone knows any option how to setup this?
Thanks,
Tom
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I believe this guide might help you out here. You can use the adapter below so you can use the HDMI port on your PC and the Mini DisplayPort or Thunderbolt port.
https://www.amazon.com/AmazonBasics-Mini...
https://itstillworks.com/use-imac-pc-mon...
Let us know if it works or not!
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
The only issue doing this is the iMac needs to be fully working.
さんによる
@danj Yes, true! The iMac needs an OS in order to do this, you can't just have the iMac without an OS to do this.
さんによる
Well, I don't think that cable will work, as it is mini display to HDMI, the cable I need is the opposite way, HDMI to mini Display. From the article on that link, it seemed that only PC with mini display output can do this, otherwise, there is no way to get it connected. Let me know if I am wrong, but thanks for your reply anyway.
さんによる
@hru1207 You can do this with Thunderbolt too. I have done this with an old iMac I had trash picked a few years ago and I used that type of adapter for my newer backup PC that had HDMI.
さんによる
I will try that adaptor and see if it works on my situation, will keep you posted. Thanks a lot, Aaron!
さんによる
コメントを追加
回答を追加する
Alex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 1,127
