do I need a new battery
my shark will turn on for a sec and turns back off. does this mean i need a new battery?
It is entirely possible that this is a battery issue. I would replace it and then re-evaluate. You will at least have a known-well starting point should further troubleshooting become necessary
このアンサーは役に立ちましたか?
I think that replacing the battery would be a great start point. I have provided a link to a replacement battery if you need to buy one and I have also included a guide on how to replace the battery.
https://www.amazon.com/HQRP-XBT1106N-Fre...
Shark Navigator Freestyle SV1106 Battery Pack Replacement
If the vacuum does not work even after replacing the battery then there is something else wrong that is to be determined by further troubleshooting.
このアンサーは役に立ちましたか?
Runs 2-3 minutes and then quits. What is the matter. Do I need a new battery. If so where do I yone
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 1,917
