My 3rd Party Apple Watch band is stuck
Hi,
I have a third party band that’s stuck on my Original Apple Watch. Apple wants to charge >$200 to remove the band, which is worth far more than the watch at this point. The release button won’t press down with this band on. Is there anywhere in the San Francisco area or via mail that I can get this repaired?
Thanks
Update (09/30/2018)
There is no visible damage. The only symptom is that the release button barely budged when trying to depress it.
The Watch, aside from the stuck band is in full working order. I would just like to get this band removed so that I can change bands again.
Thanks
この質問は役に立ちましたか?
5 件のコメント
I was thinking that drilling out the band would be the best answer. I tried WD40 already, but I’ll try it again.
anonymous 2634 さんによる
Just had Apple store tech handle the same issue. They use alcohol rather than oil.
Alan Garber さんによる
Dish soap and warm water worked like a charm!
epley さんによる
Same thing happened to me just had to keep on trying and wiggling and it eventually came out.
Paige さんによる
Per Alan Garber’s comment above, I used alcohol and it came right off!
ecc77sd さんによる
