Are there antenna connector jacks on the board?
On the board of the Samsung Connect smart mesh router, are there antenna connectors on the board? If there are, what style plug are they?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Here’s a link to the ifixit Samsung Connect Home Teardown guide.
In Step.5 of the guide it mentions:
“On the back of the board we spy the Z-wave antenna (the black rectangle on the left), and some metal contact clips mounted in the case. The board has some coaxial connectors, but seems to be using spring contacts instead—a nice repair-friendly, low wear connection option”.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
You'll need to get a high frequency oscilloscope to see if you can isolate out which connector(s) are the WiFi and what frequency they support as they are not labeled.
過去 24時間: 2
過去 7 日: 10
過去 30 日: 13
今までの合計 94
