メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 home button not working.
Hi I replaced my battery and think my problem is the 2 connector pins of the home button have been pushed down in the process but I can't not for the life of me find them, ive tried searching every where for pictures, could some one please help by posting a close up picture so I can locate them . Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The iphone screen home button connects through the screen connectors.
There is also a small connector on the screen near the home button.
Check the small connector, can’t remember if it was to the left or right of home button (left I think) but it clicks onto a connector that is glued to the back of the screen. If this is OK, re- seat all your connections that go to the screen, be careful though, they should not be forced and should click in with a small amount of force when lined up correctly.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eliza Annett さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 37
