メインコンテンツにスキップ
1.4GHz/1.6GHzプロセッサー、64GB/128GB のSSD
162回答 すべてを表示
Dot (.) and comma (,) not functioning on the keyboard. How to fix it?
All other keys except dot (.) and comma(,) are not functioning. I thought by formatting the laptop will solve the issue but I am stuck as I am unable to use (.) to put in my apple ID. I have erased it completely and was trying to reinstall the OSX 10.7 lion but don't know what to do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Have you tried connecting an external USB keyboard?
さんによる
コメントを追加
1 件の回答
Have you tried using an external keyboard?
If it works in the external keyboard, the mechanism below the keys are most likely defect, which is fixed by replacing the entire keyboard. This is quite a time extensive and difficult repair. But if done carefully, it is doable.
What might be another solution you can try since the keys aren’t working: you can take the keycap of the keyboard, by sticking something like a guitar pick under the key (check google/ifixit to see how to). Cleaning it and trying to press the mechanism without the key, will show you if the keyboard underneath the keys is defect or not.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
milind さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 33
今までの合計 2,225
