メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Replaced Battery, % Now Inconsistent, Coconut Batt says "Failure- yes"
I replaced the swollen OEM battery in my MBP 2012 with one from ifixit. However, since doing so, the few times I’ve had to use it away from a power source, the battery percentage drops immediately from 100% to 94% and then falls quickly until the MBP goes into hibernation at around 40% - I might get slightly over 2 hours use out of it.
I’ve tried the SMC reset listed here: https://ifixit-eu-en.helpscoutdocs.com/a.... No joy.
I’ve installed and run Coconut Battery, which says “Battery Failure - Yes” amongst other things (I will try to attach the screenshot)
Is there anything I can do? Or do I have a dud battery and need to replace it again?
Thanks,
David
Update (09/21/2018)
Coconut battery screenshot:
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You’ll need to get a replacement battery. There appears to be a problem with it. Look at your paperwork for the return instructions.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you - I will do that!
さんによる
コメントを追加
回答を追加する
David Fardon さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 4
今までの合計 174
