two broken 30-inch cinema displays hoping to make one working
Hi,
I have one with short-short-long blink issue (display 1)and one with blank display (display 2)but the led is not blinking (continuously on).
how would you move on to make them into one working 30-inch Cinema Display?
display 1 shows an image when doing the flashlight trick against the screen.
display 2 doesn’t
thanks for your advise
この質問は役に立ちましたか?
5 件のコメント
@mayer This might be a good one for you sir.
[deleted] さんによる
What are the Axxx numbers from the bottom of the stands? It may look like A1407.
mayer さんによる
A1083 on both displays (30 inch)
Perry zelck さんによる
Apple Cinema Display 30-Inch (Aluminum) Specs
Identifiers: Aluminum - M9179LL/A - A1083
mayer さんによる
solved : I took the inverter board form the display with continuous led (no blinking led) and put it in the display with short-short-long and works perfectly now
Perry zelck さんによる
