メインコンテンツにスキップ
日本国内では2017年7月13日に発売されたNintendo 2DSの後継モデルのハンドヘルドゲームコンソールです。海外では「New Nintendo 2DS XL」として販売されています。
20回答 すべてを表示
My nintendo 2ds xl wont turn on?
It wont turn on. I have it plugged in. The orange charge light is on. But whether it is plugged in or not, when i push the power button, the blue light comes on for about five to ten seconds and then shuts off. No screen activity. And you can hear it shut off. It makes an audio click off type sound. Whats the diagnoses? I had it in my back pack. Too much pressure?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
2 件のコメント
i as well like ass
さんによる
love you kyle
さんによる
コメントを追加
4件の回答
ベストアンサー
Hey, Kyle. This can be caused by a couple different things. The first place to check is the battery. Remove the battery and inspect the three gold terminals for signs of corrosion. Then inspect the corresponding terminals on the board. clean these carefully and reinstall the battery.
If that doesn’t fix the problem, you’ll need to open your device further and check the two ribbon cables on the board (or any of the other 6). Based on what you said about the popping noise and the pressure of your backpack I would say this is most likely your problem. You need to make sure the two gold colored ribbon cables aren’t loose or damaged and that the pins on the board are also not damaged. Be gentle with the cables. If the cables are properly seated your screen is likely damaged and will need to be replaced. Let me know how it goes. Hope this helped and good luck!
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I had the same issue, and I'm aware of how the 2ds xl works. So my instinct was that I had a bad cable or display, but then I heard you mention the battery. When I took out the battery it looked just fine, so I thought it couldn't be the battery. I reinstalled the battery and then the 2ds xl turned on just fine.
So in short, it may be possible that you have the same issue that I had. Try taking out and plugging the battery into the 2ds xl
さんによる
コメントを追加
We have an issue where it knowingly got wet, but still charges, but won’t turn on. How do we fix it?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
My 2DS XL is brand new and now the screen won't turn on the origin light and red and blue lights come on but not the screen. What can I do?
さんによる
I was having This same problem and then i just smacked the back of it like 15 times and it works now. https://c.tenor.com/p6od-lJcYHwAAAAd/the...
さんによる
I had mine too for a bit I just did a battery change one of the speakers broke but when I try to turn it on not even a light just a quick flash on the screen and a popping noise
さんによる
コメントを追加
my console was working but touch was not working
so i change the touch and now it charge but not turn on ? ?
i checked all cables no sign of life
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My 2ds XL won't turn on it shows a blue line at the bottom and it does a clicking sound after 5 sec and I charged it and it no work me sad 😭
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Tried removing the battery and putting it back in, still doesn't work, checked all the cables and nothing is broken
さんによる
コメントを追加
回答を追加する
Kyle さん、ありがとうございました!
統計データ:
過去 24時間: 14
過去 7 日: 70
過去 30 日: 233
今までの合計 28,128
