メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
678回答 すべてを表示
Why restarting after screen replacement, won’t restore with iTunes?
Replacement screen install, continually restarting, disconnect the front camera and starts normally. A few minutes later restarting again, won’t restore with iTunes. Put original screen back, restarting again.??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Thank you for the response. I previously tried the old screen bare-bone ( without small parts) and restarting continued. This is the second replacement screen in three days. The first one caused boot loop. Replace old screen and all but earspeaker and front camera worked. This second screen started fine when front camera disconnected. Restarting continued regardless of front camera after a few attempts at adjusting it.
Won’t restore with iTunes, the process kicks it out of recovery mode error 4013. Began powering on into recovery mode, Used 3UTools to exit recovery mode and back to restarting loop.
さんによる
コメントを追加
1 件の回答
Try putting in the old screen if you still have it and tell us if it keeps happening with the old screen.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
just now by Gordon W
さんによる
45 seconds ago by Gordon W
さんによる
Here is a support article related to the error code you got when trying to restore. https://support.apple.com/en-us/HT201444
さんによる
I have already been there. This particular device is the most problematic of all that I have repaired.
さんによる
@gstar Maybe try contacting Apple Support because Apple still services and supports these devices.
さんによる
コメントを追加
回答を追加する
Gordon W さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 103
