メインコンテンツにスキップ
2015年11月11日にAppleより発売されたハイパフォーマンスタブレットコンピューターです。
131回答 すべてを表示
Random touch responses after screen replacement
After replacing display there are many odd random actions occuring. Ie.. I open YouTube and the fifth video on screen starts playing and soon after starts skipping to next video repeatedly. But YouTube music doesn't do this. Telegram messaging randomly switch to different conversations. But Hangouts messaging does not. I couldn't even type this up in the browser because it will repeatedly delete the message but for some reason it's kind of working in Google keep, it's just randomly selecting text making it difficult. It also randomly pasted my clipboard a few times. It seems to be getting worse. After swapping the display it was just the YouTube issue.
  Yes I fallowed the instructions to the T. Made sure to separate the battery connector before unplugging the display. Is it possible my display is faulty or damaged? My iPad is barely usable now
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
This sounds like a logic board issue, not a screen issue. What happened to the Pad that you had to replace the display?
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Dropped it. Screen was cracked. Worked for 5 days before I replaced the screen
さんによる
Are you having any issues or symptoms that would lead you to believe the display is at fault? Any artifacts, streaking, partial display?
さんによる
No, just the random touch events. Note, I am not touching the screen when it happens.
さんによる
I am only assuming it's the display since the iPad was working fine until I replaced the screen.
さんによる
コメントを追加
Did you get your screen from iFixit? It should be working 100% perfectly if so, contact iFixit customer support and request a new screen if it’s not working right. If not, there’s a 90% chance it is faulty because getting a new screen elsewhere is a roll of the dice. I suggest you order a new one from iFixit, and watch this guide for installation.
iPad Pro 12.9" (2015) Screenの画像
製品
$249.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I did purchase the screen from ifixit. I'll contact customer support, ty
さんによる
threethirteeneleven - Big sigh of relief for you, because iFixit customer support works wonders! Have a good rest of your day.
さんによる
コメントを追加
回答を追加する
threethirteeneleven さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 108
