メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Boot loop caused by broken proximity thing?
Hello
I recently replaced my iPhone 6 screen.
During replacement, I broke my proximity meter thing.
The phone powered up fine, everything was working except for the proximity thing (when I made calls and held the phone up to my face, the screen didn’t turn off like it usually did).
The battery eventually died, and when I tried turning the phone back on, it got stuck in a boot loop. The apple logo seemed to flicker in brightness and sometimes I would get a red screen flash.
Other posts on here suggest disconnecting the cable and then trying to boot the phone up.
I did that, but the phone is still stuck in a boot loop with a red screen flashing sometimes. I also tried disconnecting everything but the home button and the screen itself. Still no luck.
Will installing a new proximity meter flex thing fix my phone?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Replace the proximity sensor cable. Then do a full restore via iTunes. It’s a hardware issue that caused a software glitch. Also try using the lcd shield from your old screen if you’re not already as aftermarket ones cause problems.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brink Laubscher さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 65
