メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
623回答 すべてを表示
No backlight after liquid damage
Should I bother replacing my display assembly on my mac? The logic board works except no backlight on the display. I ordered a used logic board on eBay, but was wondering if I should order a replacement display as well.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi Paul,
It completely depends on why there is no backlight. There could be residual corrosion that needs to be addressed. It could be that the backlight on the display itself has failed. With liquid damage, I would suspec that the logic board is the issue. It is certainly repairable by a shop with the correct equipment and knowledge.
Cheers,
Joshua
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
There is no visible damage anywhere on the board. I did a continuity check on the fuse labeled "P" according to some Google results. It appeared fine. I wasn't completely sure how to do a voltage check and didn't want to damage the board further. Also, the pins are so %#*@ small the probes on my multimeter would touch the adjacent pins and give me useless readings.
Also, after I had already seen a non-working backlight, I tinkered around with the LVDS connector cable...accidentally, and, successfully plugged it back in upside down and burnt a solder joint (I think that's what it's called). So I tried messing around with my soldering iron and flux and...probably ruined it more. The Mac still boots up...without backlight. I stopped touching it and ordered a new logic board lol.
I WAS going to try and replace the LVDS cable, but multiple experts have told me that I WILL break the glass. But, I'm not entirely sure yet if the display itself is the problem of the backlight.
さんによる
コメントを追加
回答を追加する
Paul Ko さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 478
