メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
Water Damage Turn On
I dropped my iPhone in the water for a quick few seconds. then took it out and placed it in a bowl of rice, after it being in there for 12 hours, it seems to turn on but the screen is still black. Once I hit the power button it turns a different color black. Like its on
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
With water damage, you have to decontaminate the logic board before doing anything else, otherwise there will be latent issues down the road.
Not every water-damaged phone is recoverable and depending on the kind of liquid (salty, dirty, filthy), sometimes the success rate is quite low. That said, IMHO, it's always worth a try otherwise we are just piling up the e-waste.
The rice myth kills too many phones...
The water is inside the phone, on the logic board and under the shields, even under the IC's. The rice is nowhere near where the water is. So while it “may’’ soak up some water vapour, the real problem is the mineral deposits that can cause short circuits or the corrosion that is taking place as the water evaporates. Leaving the power on the device accelerates the process. The longer you let a phone sit in rice, the more time you are giving corrosion to damage your logic board. The saltier or harder the water is, the more damage will occur.
On some phones, rice treatments appear to work. But those are phones that had minimal water ingress and not anywhere near a danger area on the logic board. They would have recovered regardless of the intervention.
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
theres probably liquid damage inside the phone that rice doesnt fix. thats why you never put a phone in rice and expect it to work. take it to a repair shop that deals in microsoldering repair as there is possibly component damage
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bre Logue さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 124
