メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Phone screen not working
The screen is black but is still lit up when I press any button, I can still press things and I hear it responding like when I touch it to put the passcode. It makes the key noises. But the screen won’t display anything. How can I fix it at home
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
You tried Resetting the device obviously i assume.
Was it dropped? Did it go into water? Was it bent?
Sounds like a bad screen, There should be guides, and i believe the tools you would need to replace the screen on this site here.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
can you tell us what you were doing prior to the black screen? Is the phone hot? is your phone damaged in anyway (software - memory at full capacity, outdated firmware, hardware - dropped it, used a really really off brand charger that messed up the motherboard)
If you want to fix it at home, I would first plug it in your computer and check on itunes to see if your computer recognizes your device. If so, back it up and do a factory reset or restore it to a previous time when your phone was working.
if neither of these work, open up your phone and check the screen digitizer circuits and your battery. what do i mean by battery? you could have a faulty battery (therefore it’s swollen and beginning to press up against the motherboard, causing issues)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
daphne morffi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 33
