メインコンテンツにスキップ
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56回答 すべてを表示
Phone is acting weird like it was back button pressing itself.
Phone is new. It was never used before. It was unboxed from the sealed package. After powering it is acting strangely. It vibrates and it looks like back button is being pressed constantly.
I have opened it up.
When it is opened it is not doing that but I can’t use opened phone :)
Any help will be appreciated. ( I have tried to change touch sensitivity but it wouldn’t help)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If the bottom lights are flashing it usually means the battery is flat and needs to charge up to turn on.
Leave it plugged in the charger for about an hour and it should turn off.
If you just opened it up sealed in box don't forget to insert the battery. (I could be wrong but this model may not have user battery)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It is not power issue. Phone is charging without problems. Its starts also without problems but after a while it acts like back button was being pressed repeatedly. It vibrates and all apps/setting are closing...
さんによる
コメントを追加
回答を追加する
smallbigsquare さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 8
今までの合計 118
