Why usb port not giving power?
My device usb port not working even no power .please help
This is usually due to a worn / damaged USB port. They would need to be replaced via soldering at a reputable repair shop.
Personally I don’t think it’s worth it for a fairly old laptop.
このアンサーは役に立ちましたか?
Power is showing in tester.
If that is the case I would check on the main board for any liquid damage or loose solder joints for the pins behind the USB ports on the board.
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 60
