メインコンテンツにスキップ
Repair information for 2Boom speakers.
10回答 すべてを表示
2 Boom bx320 Not Connecting to Bluetooth
I’ve been trying to find something online even an instruction manual but it seems no matter what I type in, nothing pops up. My question is, is there a way to factory reset the speaker. Keep in mind it’s not a power button but a power switch on it so I can’t try anything with that.
It used to work just fine and then it randomly decided to stop connecting bluetooth. It doesn’t even show up on devices available to find. Any help would be much appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
9 件のコメント
hello there
does it have a clickable volume button ?
さんによる
Yea, and a pause/play button.
さんによる
Can you give us a bit more here, who makes it? Can you post some pics so we can see the unit? iFixitでの質問に画像を追加する方法
さんによる
Also, it's made by 2Boom and the model number is BX320
さんによる
I also have the same problem! Have you gotten any word from the 2boom website? I haven’t yet!
さんによる
4件以上のコメントを表示
コメントを追加
4件の回答
最も参考になった回答
Hold both volume buttons down. Then press bluetooth button box should cut off turn power on then u should be good to go
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thanks. Worked for me.
さんによる
What if it's an "no volume button"..?
さんによる
It has no volume bottom. How do you reset it?
さんによる
コメントを追加
I had this same problem but all I did was turn it down && it started working , it kept cutting off after it connected to my phone but I started playing around with it that didn’t work either but I turned it down cause I remember getting notifications about it being too loud if you have a iPhone you know what I’m talking about but I tried it && it worked
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Here’s 2Boom’s web site: 2Boom Can’t find any online support you’ll need to ping them directly.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How to make the buttons on the back work. /radio /up volume down. Skip song's ect.
さんによる
コメントを追加
I have this speaker - I had to unpair the bluetooth of one machine in order for it to pair with another. Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
exokiba さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 37
過去 30 日: 154
今までの合計 12,172
