メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
708回答 すべてを表示
iMac mid 2011 27" Flashing #1 LED new power supply. Will not turn on
I bought this 2.7 GHz i5 27” iMac from OfferUp and the seller said it was diagnosed as a bad power supply.
I replaced the power supply and now I just get a flashing #1 LED. It will not turn on.
As soon as I press the power button the LED goes out. I release the power button and it begins flashing again. I don’t know the history of it. It does not have water damage as far as I can tell and the fans and heatsinks are clean.
I changed the NVRAM battery, tried to reset the SMC, pulled the RAM, checked all the connections and still it’s a no go.
Does anyone have a suggestion what the problem is. I have been racking my brain for 3 days over it.
Thanks
Brian
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Brian  since LED #1 does not even come on, this seems to be directly related to the power supply.
LED #1 = Power available.
If no LED is visible:
• First disconnect the power cord from computer, then reconnect it to reset the LED status, in case computer was correctly shutdown and AC was kept connected since
• Verify AC source
• Verify known-good power cord is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You’ll need to pull the logic board to inspect the other side. Look carefully on both sides for damaged components (burnt or missing) use these IFIXIT images for reference back of board & front of board
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brian さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 243
