メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TDK Life on Record A33は、耐候性を備えたBluetoothスピーカーです。2012年に発売されましたが、現在は生産を終了しています。
MacBookPro connecting to bluetooth and telephone at the same time.
I was trying to use my TDK A33 today with my 2014 MacbookPro and the sound was being muffled. My computer was connecting to the bluetooth, but the telephone button was turning on and connecting at the same time and the sound was getting really distorted. I tried repairing with bluetooth and not the telephone, resetting the TDK bluetooth options, and tried restarting my MacbookPro, but nothing has worked so far. When I connect to other devices both my MacbookPro and TDK A33 work fine however. Please help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
By chance did you link up your phone as well as the MacBook to your speaker?
さんによる
I did connect my phone to the speaker, but i thought of that and made sure to disconnect and forget the connection from my phone.
さんによる
コメントを追加
1 件の回答
Did you try resetting the speaker? While the connection to the phone was severed the speaker may still think its active.
I would check the volume levels within both the Mac & speaker. Try lowering the Mac’s volume to about 1/3 as well as the speakers.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Yeah I did reset the speaker to see if that solved the problem, but it still was connecting to bluetooth and then turning the phone button on automatically.
The volume is still working fine, what's off now is the sound quality, it's a lot worse than it was two days ago when everything was working perfectly. Also I connected my speaker to two other devices, my phone and another MacbookPro to check and see if it was the speaker having issues with them, but the sound quality was back as it should be when i played the same song through them.
It looks like the issue is only happening when my MacbookPro connects to the speaker.
さんによる
How far is the speaker from your MacBook Pro? Less than 12 feet.
Bluetooth signal is not likely to be bad audiowise. You are sure other speakers are working with your system.
さんによる
Yes. The speaker is less than a foot from my MacBook Pro. I haven't tried my Mac with other speakers, but I have used Airpods and the sound has been fine through them.
さんによる
Well what can I say if your Airpods are working then that proves your systems Bluetooth is OK. I think you’ll need to talk with TDK as I have no answer for you. Sorry
さんによる
Okay! I'll try and contact them. Thanks for trying to help me out. I appreciate it!
さんによる
コメントを追加
回答を追加する
James McGill さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 14
過去 30 日: 19
今までの合計 259
