メインコンテンツにスキップ
Roku Streaming Stick's first model, shown here, was manufactured in March 2014. Since its launch, there have been 10 million units sold.
Why are you not able to mute music through Roku remote?
Hi,
I just want to know that Why i'm not able to mute music through Roku enhance remote. Please help me to solve this problem.
Thank You
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
I don’t believe there is a mute function for the Roku device. You can pause the streaming with the play/pause button.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
yes there is
さんによる
Post a link please, this site is all about sharing. You mean this one...
https://www.amazon.com/Universal-Control...
If so, I stand corrected.
However, the above is NOT a standard roku remote but an aftermarket remote. It likely requires programming (setting to your make/model of tv) to make it work correctly.
さんによる
コメントを追加
If you are connecting your Roku player to your TV and not through another device such as an audio/video receiver , then try the following:
  1. Check the volume level and mute settings on your television.
# Make sure mute is OFF and that the volume setting is at an appropriately audible level.
  1. If you are using a composite cable, check that the audio connectors are snugly attached at both ends.
  2. Connect the Roku player to a different input and see if you can now hear audio. If you can, then there is a problem with the previous input on the TV.
  3. Try changing the cable.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lilymitchell さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 8
今までの合計 630
