Jura Impressa S95 stops alone
Hi all,
My Jura Impressa S95 will stops on its own after few minutes, then, we I press the power on button, she stops immediately (less than 2 seconds). Íf I wait few hours, it will turn on, make 1 coffee and stops on its own again.
I am suspecting an overheat security feature (i.e.: defect PT100 - if they use these ones).
I also replaced the electronic card and the problem still persists.
Can someone help to troubleshoot it and tell me what to look at?
Thanks
Firstly, I'm NOT an expert but an electrician that can read drawings. Which electronic card did you replace? The power PCB or logic PCB? If it was the logic PCB, then the only thing I can think of is a bad in-line RF filter causing the system to be vulnerable to EM fluctuations. That could cause a myriad of problems in the delicate circuitry. If you replaced anything BUT the logic PCB, then I would do so. It contains the components that "latch" the power on when the power button is pushed (in standby mode), and the timers that shut it down after a specified period.
Christopher Cook さんによる
