メインコンテンツにスキップ
MacBook Proの13インチディスプレイ搭載モデルの修理情報・ガイドです。
9741回答 すべてを表示
My MacBook shuts off after about a minute
When I log on to my MacBook Pro it works for about a minute, then it shuts off. It won’t start up for about 5 minutes afterwards, I originally thought the problem was the origin application as it has caused some problems in the past, but after deleting it it still shut down. There has been no water damage. Sometimes it makes a noise like a taser but there are no sparks and I haven’t been electrocuted. Help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
What is your exact model? You can look it up here: EveryMac - systems listing
さんによる
コメントを追加
2件の回答
ベストアンサー
It might well be a overheating issue. Try unscrewing the bottom plate and see what’s the fan condition. If it’s full of dust you’ll have to remove it and blow it clean and check the heatsink is not clogged too.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I think this is going to need a bit more than cleaning if he's hearing "Sometimes it makes a noise like a taser" sounds like a capacitor or coil has failed on the logic board.
さんによる
コメントを追加
You likely have a bad component or two on the logic board. Make a good inspection of both sides to see if you see any burnt damage. Once we know what your exact model is we can guide you on how do remove the logic board or you may want to find someone local with Mac skills to do it for you.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I shut it down for the night and it seems to be fine now. I’ll take it to a repair shop sometime soon as I am terrified of taking it apart lol. Thanks for the help!
さんによる
コメントを追加
回答を追加する
Amy Lester さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 41
