メインコンテンツにスキップ
基板とCPUのための修理ガイド
166回答 すべてを表示
Computer stops at loading, forcing to go into BIOS settings
Every time I turn on the computer it stops loading in the screen where I have to go to the bios (by pressing F1) and then reboots and then normally loads my user profile. How come every time where do this step? do I have to change any settings in the bios? if yes, what should I change?
my pc: https://imgur.com/YTnGeSz
https://imgur.com/Pz6ooMh
https://imgur.com/ZNzhvPc
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
If you need to configure or set up your computer motherboard’s CMOS, BIOS, or chipset, see the Motherboard CMOS Configuration and Setup page for instructions.
As Guarav Kumar suggested and from reading the additional comments, replace your motherboard’s CMOS battery. This is typically a CR2032 3V coin-cell battery widely available at virtually any electronics store or online.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
the battery to which you refer is that of the asus maximus vi gene right? What do you see in this picture?
https://imgur.com/dJTvGm0
I will try to change this battery and I will let you know if the problem has been solved
さんによる
Guarav Kumar and TechWizard thanks i just change the BIOS C-MOS battery  and now it all works very well
さんによる
コメントを追加
回答を追加する
alberto hotmail さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 206
