メインコンテンツにスキップ
Repair information for the Beats Studio 2.0 wired headphones. Originally released in 2013. Model number: BT OV STU BLK.
88回答 すべてを表示
Beats hinge broke, and now stuck together
Hey, so i finally decided to fix my beats, about two years ago part of the headband broke and got stuck inside of the hinge, so i got really nervous and just used tons of super glue to get it back in place, as a result of that super glue got inside the hinges and now i cant extend and fold the left side.
I Know i need to replace the hinge and headband(already ordered them) but what about the inner and outer panels? they are glued to the hinge and probably break when i try to get them off, is there a way to get them off without breaking them? or and easier way to fix it?
Thanks
Im Sorry its a bit dirty, It was held together with electrical tape for 2 years!
btw, this is the right side which has the exact same problem the left side has, but i didnt glue this side, after i saw what i did to the left side.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Ofek Tal  try to use a heatgun at the lowest settings to warm up the glue so you can remove the panels. To see if there are other ways for the repair we would have to see whaere and how it broke. Post someimages of our damage with your question. Use this guide iFixitでの質問に画像を追加する方法 for that
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Hey, I Will try that, sounds like it could work. but will i be able to reuse the same inner and outer panels, as they are covered with glue and it will probably affect the sliding.
I Added the images. :)
さんによる
Ofek Tal darn you pumped teh glue in there for sure ;-)
Once you can remove teh parts I would try and really clean it with mineral oil first (superglue disolves in il) and after that with some isopropyl alcohol. You will find that warming it up will soften it, so do that first. Tough job and it will require quite a bit of elbow grease ;-)
さんによる
Yea it really got in there.
Ok so heat and oil to soften and get the glue off. I Hope i will be able to seperate the panels without breaking them.
さんによる
....keeping my fingers crossed and hope it'll work out for you.
さんによる
Hey thanks, i got my hinges and headband today and started the disassembly, but the panels werent seperating at all. the glue got all around the edges and even covered the wires, so i had to break it. but i got all the important stuff, I Just need to order the panels and they will be just like new,
P.S using a heatgun really helped, thanks for that. but there was too much glue and i didnt want to heat up the headphones too much.
さんによる
コメントを追加
回答を追加する
Ofek Tal さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 494
