メインコンテンツにスキップ
This is the original Chromebook Pixel branded laptop released on February 21, 2013. This device is at the high end of Google's Chromebook family of machines, which all come preinstalled with Chrome OS operating system, as part of the Google Pixel series. The 2013 Google Pixel comes in two varieties: the Wi-Fi version and the LTE version which uses the Verizon cellular network.
Can I repair my adapter cable?
it is possible to reconnect the the cable to the adapter in a clean way? its giving issues and finding a replacement charger is tough
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
My adepter is not working
さんによる
コメントを追加
2件の回答
最も参考になった回答
Karim Esquivel  it sounds like you are talking about the AC adapter. You can remove part of the wire and resolder a new adapter. Post some pictures of where you think your wire is bad and what the adapters ends look like. Use this guide iFixitでの質問に画像を追加する方法 for that so that we can see what you see.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had the same problem. I could not find the same plug (connector), so I cut off the cable from the original adapter and mounted it to an universal adapter for the correct voltage. I can't remember what the exact specification was (I think it was 12V), but I can look it up if you're interested.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Karim Esquivel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 368
