メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
1364回答 すべてを表示
home button ring is raised from top
hey guys I have bought a 7 plus yesterday and what I have noticed is that the ring on the home button is a little bit raised or sticking out on top and perfectly aligned on other sides, it works fine though the touch, the taptic engine. I have a 7 also but it is fine, also the sim tray is not original it doesn’t have a seal on it. the main concern is TOUCH ID. Should i return the phone and get other one or is it okay and I continue using it. will it get damaged or failed?
its so much minor that I could only feel it by swiping my finger over it and by looking very closely to surface I can see it a bit raised on top …
Please describe the best solution
Thanks in Advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
I think it should be fine. Maybe its a refurbished unit from a local shop and the screen had been replaced.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This sounds like a privately refurbished phone, do not consider it be new or waterproof or perfectly repaired.
If you bought it for cheap “as is”, I guess it’s OK. If you bought it as “new” or “almost new”, talk to the seller.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I would honestly just re-seat the home button as it is possible to get a pressure crack and loose certain functions. If the phone was refurbished and the screen was replaced, there may not have been enough attention to detail when seating the home button.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sania Nadeem さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 434
