メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
touch ID works after screen replacement but only for a few clicks
hello, recently I replaced a broken screen out of my iphone 6S, i carefully installed everything back im place and everything worked just fine, but suddenly, the touch ID stopped working, no message like “TouchID od dissabled” to anything, homebutton still works.. Then I took it apart again, reinstalled both touch ID connectors one the homebutton and into the motherboard, it worked again but for like 20 unlocks and then the same problem occured… This was repeat like 6 times and same results.. I’m hopeless, should I get a new screen or is there anyone who can help? Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Try another screen :)
さんによる
If you put the broken screen back in, does the problem go away?
さんによる
コメントを追加
2件の回答
最も参考になった回答
id check home button flex that attached to shield, does your old screen work with home button. also back up and fully restore phone. did you use enough heat to pull away the home button? check for any type of damage.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This is a common screen issue on some bad screens where the flex that runs under the plate isn't very good or is damaged…
Assuming the button wasn't damaged during removal or fitting then try another screen, you could also try to remove the flex from the original however that's quite awkward if you haven't done it before
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mark Bear さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 31
