How do I get audio in left side of earbud/headphone?
After I repaired my sister's iphone 6 lighting port the audio from the headphone jack only comes through the right side and not the left. How do I repair this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Settings >general > accessibility
Scroll down to hearing.
Make sure all settings are normal. Adjust the slider to make sure it is centered. If this is already centered then try new headphones, the ones your using may not be working properly. If the problem persists then unfortunately the lightning port you used is bad and will need to get another one.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 44
