メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Stripped screws. ifixit screw extractor not working
Hi I purchased the screw extractor kit to try and get 3 screws that where stripped by Apple when they repaired my screen.
I have tried all the bits but not one has worked for me.
would someone be able to help me with this, I can't clean my mac which I know is dusty inside.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Booked a Genius Bar appointment and they got them out and replaced them for free out of warranty and out of Apple care.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
If you or a friend have available one of those rotary tools such as a dremel or the likes you can use a round shaped thin cutting tool to create a slot on the screws head and use a flat head driver to get rid of the stripped screws. You have to have a steady hand but with some care you should manage. That's my favorite way to win smaller stripped screws.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
I do and would do that, however I would end up cutting the unibody
さんによる
You could try using a jewelers hand drill with a left hand drill. going slow and easy pop the head of the screw off then use a good jewelers gripping plier slowly twist the shaft off. Often times just the act of drilling will loosen the screw.
さんによる
I have just booked it in to apple and I have to prove that I did not damage them cos this happened after i replaced the screen by apple. I will just say that there is so much dust inside how could I have ever opened it.
さんによる
Apple fixed it today at no charge, changed all the screws over and got the stripped ones out.
さんによる
コメントを追加
回答を追加する
Luca Chana さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 6
今までの合計 779
