メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone does not want to turn on
I got a IPhone 6 here that does not want to turn on.
I can confirm the battery is still good because when I move the battery over to another IPhone it starts right up.
Battery does have juice in it, it is not dead.
The LCD is bad however but it should still turn on.
I don't think it's black-light damage because the phone should turn on if it was.
I've tried:
  1. Holding Power button and home button for 1+ minutes.
  2. Connecting to a Computer, (Computer does not detect phone)
  3. Use a brand new screen and LCD, still no luck.
  4. Left it to charge for more than 1 hour
Any ideas?
I appreciate it!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Blown U2 IC is culprit. need to have a micro solder technician replace the tristar!
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
What can cause it to blow ? Isn't the U2 IC chip responsible for charging?
さんによる
It is responsible for the charging, data connection to the computer and providing information to the pmic chip. Using third party cheap cables will damage this chip.
You experience not charging, not turning on... very likely the U2 IC but could also be the a vcc main short somewhere or the PMIC chip blown. The only way to know is to have good use of multimeter and board schematics to pin point the problem. We do this daily and see vcc main shorts and u2 shorts all the time.
さんによる
Also another thing to note need to look under the metal shields for liquid damage on logic board IC components
さんによる
How does a cheap cable cause the chip to blow? Wouldn't it be the charger's fault rather than the cable?
さんによる
コメントを追加
回答を追加する
Richard Danh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 68
